Full Version: Loading stored Quickset data resets RF Power to 0 Watts
I noticed that every time I load saved settings from the Quickset memory, the RF power resets to zero %. Power setting was set to 100% before the Store button was pressed.
Also loading the settings saved under button #1 turns the volume down on the radio. I did not observed that problem with the other memory buttons.
73, Ted VE7VIB
I tried it but it works well, I have no problems with the QuickSet key 1.
Check that you have installed the latest version (ver. 1.3.4), if it does not work, delete the file QuickSet.dat that you find in the installation folder and repeat storage.
