11-16-2014, 10:47 AM
Method 1:
1. Unzip the registration key file received by email in the program folder (default: C:\IZ2BKT\IC7100BKT Icom CAT Control).
2. Run the program IC7100BKT, the key will be automatically loaded and deleted from the folder.
Method 2:
1. Unzip the registration key fileĀ <call.ic7100bkt.bkt> received by email in a folder.
3. On Utility tab click on [Register the program]
4. On registration dialog click on [I have the key, load it]
5. Select the unzipped file in the folder used in step 1 and press [Open]
6. At the next run the program will load the key into its database and delete it from the folder.
To check if the program is registered look in the title bar:
![[Image: FreeVersion.png]](https://www.maniaradio.it/forum/images/FreeVersion.png)
![[Image: FullVersion.png]](https://www.maniaradio.it/forum/images/FullVersion.png)
Method 2:
