09-24-2015, 09:28 AM
09-25-2015, 07:20 PM
DK1KW Wrote:Hi,
is it possible to use BKT7100 as a CW keyer for the IC-7100?
Can I run the CW memories with BKT7100?
Werner DK1KW
Hi Werner,
the IC-7100 has not a software command to transmit the memories CW.
A CW keyer will be available in future versions of IC7100BKT, in the meantime, you can program the Custom Key for sending phrases CW:
enable Full BK-IN o Semi BK-IN and use the command 17 (pag. 20-4 IC-7100 Advanced Instruction Manual) for Custom Key.
Ex. for sending CQ CQ in Custom Key Command put: 1743514351FF
