Full Version: Logger32
I have a problem using logger32 along with 7100bkt software due to obvious reasons.
I want to have control over icom with logger 32 and 7100bkt simultaneously which cannot be done for the moment because they share the same serial port.
Is there any alternative ???
thx..
You can't share the same COM port between two programs CAT.
IC7100BKT is compatible with BBLogger (http://www.bblogger.eu/), HrdLog (http://www.hrdlog.net/) and all software using the DxLab DDE Protocol
solution found to share serial com ports through software <!-- w --><a class="postlink" href="http://www.eterlogic.com">www.eterlogic.com</a><!-- w -->
kxrist Wrote:solution found to share serial com ports through software <!-- m --><a class="postlink" href="http://www.eterlogic.com">http://www.eterlogic.com</a><!-- m -->
I know the product but I have never tried to share two different CAT software to the same COM port. If you did, please let us know the results and your configuration. Thank you.
