IC7000BKT Cat Control for Icom IC-7000
General discussion - Problems - Bugs / Generale - Problemi - Errori
> VFO B stays in Memory mode
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
oe1gqa
05-11-2017, 11:38 AM
When I switch off the memory mode ( memory mode was FM split ) then the VFO B stays showing the split frequency of the memory, When I press VFO B and then VFO A again then it shows the correct VFO B frequency
iz2bkt
05-12-2017, 07:04 PM
In the IC-7000 you can read only the values of the active VFO, then you cannot update the status until the activation of the VFO interested.
