12-16-2018, 02:22 PM
Guide to using IC7100BKT with WSJT-X, JTDX, MSJV:
IC7100BKT Version 1.13.0 and later:
- In IC7100BKT go to Utilities -> Configure
- Enable LAN Protocol on port 52002
- Confirm with OK
In WSJT-X or JTDX:
- Go to File -> Settings -> Radio
- In Rig select DX Lab Suite Commander
- Confirm with OK
In MSHV:
- Go to Options -> Interface Control
- In the Network box -> Server type 127.0.0.1 and in Port type 52002
- In RIG select DX Lab Suite Commander
IC7100BKT versions prior to 1.13.0:
- Download and install BktNetInterface
- Start BktNetInterface
- Select the CAT in use (IC7100BKT)
- If you want the connection to start automatically when you open the program, check "Auto-start in system tray"
- Click "Start"
- Start JTDX or WSJT-X
- Go to "File" -> "Settings" -> "Radio"
- In "Rig" select "DX Lab Suite Commander"
- Close with "OK"
To start BktNetInterface with the CAT:
- Start IC7100BKT
- Go to "Utility" -> "Startup"
- In "Description" write "BktNetInterface"
- In "Program" select "BktNetInterface.exe" from the installation folder
- Click "Save"
It is recommended to start IC7100BKT first and then JTDX, WSJT-X or MSHV.
- Confirm with OK
In WSJT-X or JTDX:
- Confirm with OK
In MSHV:
- Click "Start"
- Close with "OK"
- Start IC7100BKT
- Click "Save"
