First of all, thank you for great application.
I have two suggestions:
1. Add a possibility to setting time difference in seconds manually. Like in TimeFudge.
It very simple but useful function if there aren't internet or gps available.
Something like:
2. Add of functionality of really outstanding app BktTimeSync Phone to the BktTimeSync.
There are two bonuses of it step:
a) One fully functional app that's conforms all possible needs of time sync for ham purposes.
b) Absence of Java
You can correct the time difference using the Offset field
![[Image: BktTimeSync_en_offset.png]](https://www.maniaradio.it/forum/imagespers/BktTimeSync_en_offset.png)
(03-21-2019, 07:31 AM)iz2bkt Wrote: [ -> ]Hi,
I don't understand how I must use "Offset" option in that (real) situatuation:
I'm in the middle of nowhere without internet access and some serious troubles with my gps equipment was occured (it doesn't work at all).
What should I do (step for step) for manual time correction in BktTimeSync to make QSO at digitial modes (ft8,jt65) possible?
Use the Windows command:
- Open the command prompt in Administrator mode
- Type TIME Hours: minutes: seconds (example TIME 10:42:25) and Enter
You Can keep the command prompt open, press the F3 key and repeat the operation as many times as you want
(03-21-2019, 09:59 AM)iz2bkt Wrote: [ -> ]Use the Windows command:
Nice try, but no
It's almost impossible to set
time offset (not new time) especially in milliseconds in such way.
Look, I don't talk about workarounds. I can invent a lot of them. For example on PowerShell:
Code:
$TimeDiff = Read-Host 'Input time difference is second (s.s)?'
$SrcTime = Get-Date -Format 'yyyy.MM.dd HH:mm:ss.fff'
$DstTime = Set-Date ((Get-Date).AddSeconds($TimeDiff)) | Get-Date -Format 'yyyy.MM.dd HH:mm:ss.fff'
Write-Host ("Src-Time = "+$SrcTime) -Foreground Yellow
Write-Host ("Dst-Time = "+$DstTime) -Foreground Green
I only want to say that it would be nice to implement such (very very simple) functional in BktTimeSync.
Hi
this is available from the BktTimeSync version 1.10.0
