Full Version: Communication problem - COM error
For communication errors try this:
- Install IC7300BKT latest version from http://www.maniaradio.it.
- check these settings in Icom IC-7300 Set-Mode->Connectors->CI-V:
CI-V Baud Rate = Auto ( in some cases you need to select the speed set in the program ex. 19200 or 9600 )
CI-V Address = 88h
CI-V Transceive = OFF
- Install USB drivers Icom (download from: http://www.icom.co.jp/world/support/down...index.html)
- From SerialPort drop-down list select the COM port with the description "SILICON LABS..."
- try to change Serial Port Mode from MODE 1 to MODE 2
[Image: IC7300BKT_SetCom.PNG]
- try to use BKTRS232 driver:
[Image: settingComRS232.png]
- try to switch ON/OFF the RTS and DTR signal
- try to change BAUD speed
- Verify that there are not running other programs that use the same COM port
