IC-7600 Support w/ fldigi - Printable Version
+-- Forum: IC7000BKT Cat Control for Icom IC-7000 - will no longer be updated and will be replaced by CatBkt2 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5)
+--- Thread: IC-7600 Support w/ fldigi (/showthread.php?tid=174)
IC-7600 Support w/ fldigi - esunetdude - 04-14-2014
I was able to get ic7000bkt to connect to my IC-7600. Most things seem to work properly. I use fldigi for most of my digital work, and have been using the fldigi gateway for Commander. In fldigi the modes should switch the rig to USB-D1 (or D2). Inside fldigi this is accomplished by using Data-U and works fine with Commander. With ic7000bkt the rig always goes to USB, not the USB-D1.
Will there be direct support for the IC-7600 model? Is there a workaround for this problem?
73
Doug N3JXB
Re: IC-7600 Support w/ fldigi - iz2bkt - 04-14-2014
Hi Doug,
IC7000BKT is designed for the Icom IC-7000 and some commands are different, try CatBkt configuring other models of Icom.
http://www.iz2bkt.com/catbkt_en.htm
