JT65-HF to IC7000BKT Connection
Hi Mauro
Thanks for responding to my request for a timed start/stop on the recorder function. Big Grin
I finally cracked the character code to join the forum! Big Grin
JT65-HF shows the frequency from IC7000BKT using the "Commander" check box but does not change the frequency when clicking on a different frequency using the drop down list on JT65-HF nor does it operate the PTT. I think it does the same with Commander and that only HRD can change the frequency and operate PTT. Is there something I am not doing? I tried starting MyDDE but could not get it to start with IC7000BKT and JT65-HF running. MyDDE works well with Orbitron though.
73 de Lorne Douglas ZL2AHB / ZL3LSD
Hi Lorne,
welcome to the forum.
What you have written is correct:
JT65-HF supports these functions only with HRD
MyDDE is only for use with Orbiton.
ZL2AHB Wrote:Hi Mauro
Hi Lorne,
is available the Version 1.15.0 where it is possible to program the automatic recording by the function skeds.
