IC-7300 does not connect at 115200 BAUD
The connection speed with the Icom IC-7300 can reach 115200 BAUD, if it doesn't work enter in the radio configuration in Menu->SET->Connectors->CI-V->CI-V USB Port and select Unlink from [REMOTE], exit the configuration with the back key and switch the transceiver off and on again.
