Full Version: IC-7600 Support w/ fldigi
I was able to get ic7000bkt to connect to my IC-7600. Most things seem to work properly. I use fldigi for most of my digital work, and have been using the fldigi gateway for Commander. In fldigi the modes should switch the rig to USB-D1 (or D2). Inside fldigi this is accomplished by using Data-U and works fine with Commander. With ic7000bkt the rig always goes to USB, not the USB-D1.
Will there be direct support for the IC-7600 model? Is there a workaround for this problem?
Doug N3JXB
Hi Doug,
IC7000BKT is designed for the Icom IC-7000 and some commands are different, try CatBkt configuring other models of Icom.
http://www.iz2bkt.com/catbkt_en.htm
