General discussion - Problems - Bugs / Generale - Problemi - Errori
Important Threads
- Efficiente interfaccia CAT USB by I2WQ (0 Replies)
- Using IC7000BKT with JTDX, WSJT-X and MSHV (0 Replies)
- Utilizzare IC7000BKT con JTDX, WSJT-X o MSHV (0 Replies)
- Come caricare la chiave di registrazione (0 Replies)
- How to load the registration key (0 Replies)
- How to localize the program (0 Replies)
- Features available in full version (0 Replies)
- How do I change my call sign ? (1 Reply)
- Improve remote connection client/server (0 Replies)
- How to change size and appearance (1 Reply)
- Connect using VSPE Virtual Serial Ports Emulator (0 Replies)
- Communication Problems - COM error (0 Replies)
Threads
- IC7000BKT Freezing (3 Replies)
- Frequency from JTDX to IC-7000 (5 Replies)
- registration not working SOLVED (5 Replies)
- Auto Power OFF (3 Replies)
- ic7000 remote e server (3 Replies)
- Accedere a BBLogger (1 Reply)
- how to save TONE setting in memory editor? (1 Reply)
- problema IC7000BKT-BktremoteServer (1 Reply)
- regolazione FIL (3 Replies)
- Auto CQ (1 Reply)
- Error 1 - Unable to open Port Com4 (12 Replies)
- Codifica DMR (3 Replies)
- Scanning all / specific memory Banks (1 Reply)
- IC7000 Add 60 Meters to band and mode (1 Reply)
- Mydde2 and Orbitron (2 Replies)
- Easy to make CI-V cable (1 Reply)
- IC-7000 Comment Column (1 Reply)
- differenze delle versioni. (1 Reply)
- cannot find activation key in email? (1 Reply)
- Registration not working... (SOLVED) (4 Replies)
- Error in the initialization of the audio support (SOLVED) (4 Replies)
- Memory naming (2 Replies)
- access to the serial number of the radio via cat (1 Reply)
- Audio Windows Warning/Failure (1 Reply)
- VFO B stays in Memory mode (1 Reply)
