Full Version: MyDDE2 won't start.
Everything else in the IC7000BKT install went easy. Went through all of the setup and configuration without any issues. Works great. Got to installing the MyDDE2 DDE server and it appears to load and shows up in the tray with a big red X through the icon. Both Pause and Start selections show in the menu. I press start nothing seems to happen. Pause causes a P to flash over the icon in the tray.
I did add MyDDE2 to the plugin section and used that to add it to the startup section. And I do start IC7000BKT first. I'm trying to connect to HDSDR via the Orbitron DDE selection. But no connections. Will it be obvious if the server starts accepting connections?
Thank you,
Ed
WD4ED
Hi Ed,
you need to configure MyDDE for use with IC7000BKT:
[Image: MyDDE.png]
1. Run MyDDE
2. Right click on the MyDDE icon in the system tray and choose Start (automatically starts IC7000BKT)
3. Run Orbitron
4. Connect Orbitron to MyDDE:
[Image: Orbitron.png]
