Full Version: Cut/paste problem
I'm running version 1.25.3 and when I try to cut and paste a memory entry, the result is the cut line being deleted without the paste line being added. i.e. I lose the entry completely.
This has worked perfectly in previous versions - so I'm guessing it's a little bug Smile
Thanks for the program,
Ross.
Hi Ross,
thanks for pointing that out, as soon as possible I will try to eliminate the bug.
Many thanks Mauro, keep up the great work.
Ross.
This problem will be solved with version 1.25.4 available soon
