Full Version: Program crashes when attempting to load registration key
I have received the registration key ZL4LVIC7000BKT.bkt and installed it in the IC7000BKT Icom cat control folder as instructed. When attempting to register the program it crashes with a Windows error message then restarts without being registered. The registration key file has also been deleted. I have the latest version of the program installed. I have made several attempts with the same results. I have Norton Security installed, Windows 7 Pro in use.
I have since tried it on another computer and the registration was successful. I suspect Norton is the problem, any suggestions?
Peter ZL4LV
Trying to exclude the installation folder of IC7000BKT from Norton.
Try this http://www.iz2bkt.com/forum/viewtopic.php?f=5&t=256.
If that doesn't work, send me an email to the address of the full key with attacched the file IC7000BKT.INI file located in the
installation folder.
