Hi all.
I try to use Bkt timeSync with a qrp-lab gps. it´s a YIC5. but no run.
The program work good with a Ntp server, but not in gps mode.
My OS is win 8.1 and gps is conected to PC like this:
1PPS--------------pin 1 of DB9
TxD--------------- pin 2
RxD---------------pin 3
Win recognice the device, and assing a COM. but Bkt TS no run.
what i´m doing wrong?
Thanks for help.
73!
Alberto-EA4GHB
Please, enable BktTimeSync Diagnostic Log and post the result
I paste diagnostic log:
Last Sync :Monday, May 22, 2017 20:30:28
Please select NTP and/or GPS sync mode
Enable GPS is select and I press SYNC NOW, but diagnostic log do not write anything more.
Thanks.
Alberto
1. Check Diagnostic Log
2. Click Sync Now
3. Close BktTimeSync
4. Paste Diagnostic Log
Thank you
SRI Mauro,
Paste now. Thanks.
Windows Versione: 6.02
BKTTimeSync Versione: 1.8.2
NTP Server:
NTP Porta: -1
NTP Offset:
NTP ON: 0
Autostart: 1
Start in tray: 0
Sync all'avvio: 0
Sync ogni: -1 minuti
Sync massima: 12 ore
GPS Porta: 4
GPS Baud: 9600
GPS Bit: -1
GPS Bit di stop: -1
GPS Parità:
GPS RTS: 1
GPS DTR: 1
GPS Offset:
GPS Always Connected: 0
Sequence: 1
Tue May 23 16:02:07 2017 --> Sync start P1
Tue May 23 16:02:07 2017 --> Sync GPS COM open
Tue May 23 16:02:08 2017 --> Sync start P1
Tue May 23 16:02:09 2017 --> Sync start P1
Tue May 23 16:02:10 2017 --> Sync start P1
Tue May 23 16:02:11 2017 --> Sync start P1
Tue May 23 16:02:12 2017 --> Sync start P1
Tue May 23 16:02:13 2017 --> Sync start P1
Tue May 23 16:02:14 2017 --> Sync start P1
Tue May 23 16:02:15 2017 --> Sync start P1
Tue May 23 16:02:16 2017 --> Sync start P1
Tue May 23 16:02:17 2017 --> Sync start P1
Tue May 23 16:02:18 2017 --> Sync start P1
Tue May 23 16:02:18 2017 --> Sync GPS COM port closed
The GPS does not send any data to the program, I don't know if it's either the links or the configuration of GPS/COM because I never tested this GPS model. You can experiment by communicating with a communications program on serial ports such as hyperterminal
