BktTimeSync
Important Threads
- BktTimeSync Version 1.15.x (0 Replies)
- Client Server Mode (0 Replies)
- Modalità Client Server (0 Replies)
- How to localize BktTimeSync (0 Replies)
- Configurare WSJT-X per Auto Grid (Griglia Auto) (0 Replies)
- Set up WSJT-X for Auto Grid (0 Replies)
- BktTimeSync non si avvia in automatico con alimentazione a batteria (0 Replies)
- WARNING: April 6, 2019 Old GPS doesn't decode the time (0 Replies)
- ATTENZIONE: 6 Aprile 2019 i vecchi GPS non decodificano l'ora (0 Replies)
Threads
- Fixed Chinese Translation (3 Replies)
- BKtimeSync - Stopped working - SOLVED (12 Replies)
- BKTIMESYNC with Windows 11 PRO. (1 Reply)
- Recommended GPS receiver (0 Replies)
- How to obtain time from Flex 8600 GPS? (1 Reply)
- BktTimeSync Version 1.14.x (0 Replies)
- Clock will not sync with GPS trimble (2 Replies)
- WSJTX Auto Grid Not Working (1 Reply)
- Virtual com port not working (3 Replies)
- Grid update interval for WSJT-X (1 Reply)
- Localize Japanese (1 Reply)
- Scheduled Task Missing from 1.13.1? (1 Reply)
- Using BktTimeSync with the Surface Go GPS (0 Replies)
- Need Help debugging performance issue (SOLVED) (10 Replies)
- BktTimeSync Version 1.13.x (0 Replies)
- Ver 1.12.1 starts then unresponsive - SOLVED (2 Replies)
- Language (6 Replies)
- Run for all Users (3 Replies)
- Autogrid setup for udp multicast (1 Reply)
- lost clock display (SOLVED) (2 Replies)
- BktTimeSync Version 1.12.x (0 Replies)
- Can't make settings anu more (1 Reply)
- BKT Sync (3 Replies)
- Build for ARM-based system (1 Reply)
- BktTimeSync not starting on Windows startup (5 Replies)
