12-01-2020, 12:27 PM
Dear Mauro,
Maybe a suggestion for future versions from BKTtime....
When you have running more applications who need NMEA position data then a conflict is there. The problem is that BKTtime claimed the serial port. The serial port is then not accessible by other applications.
Would it be an idea to implement UDP I/O for the NMEA data?
In that case you can choose if you get data from an other running aplication or send it as UDP to other aplications.
With kind regards, Jugo
p.s. fine software!
p.s. fine software!
