Threads: 1
I have un-installed previous versions of the IC-7000 software. I just installed latest version (ic7000bkt_Setup.exe). I try to load my registration file. The program CRASHES.
I have done this over and over, disabling virus protection, etc.
I am on Windows XP.
I really need this to work. Perhaps the key file is corrupt? Or something else?
Please help me. Thank you
Tomas David Hood (Amateur Radio, NW7US)
Threads: 190
5
Hi Tomas,
try this:
1) Uninstall the program
2) delete the program folder
3) install the program
4) load registration key
if this does not work, send me the file ic7000bkt.ini via email.
Threads: 1
I've just sent the .ini file - as I am still getting the error.
Thank you.
Threads: 190
5
Hi Tomas,
I tried your INI file and see that the program has registered regularly.
I tried using your INI file and load your file key but does not give me any error and works well.
Verify that the program is installed in a folder with write permission.
Excluding the error to load the key, the program works ?
Threads: 0
Just as a point of reference that might be of use to the Admin in troubleshooting your bug, I have been using the BKT7000 software for awhile now (I like it), and I just noticed the latest 1.12.0 build about an hour ago. I did not delete the old version that I was using before I installed the latest update (I didn't think it was required), and the update took place without any drama at all. After the update was complete, I opened the application, and it was at the latest level, with all of my registration info intact.
I'm running Windows 7 64. You mentioned that you are running XP, and it might be possible that there is an issue with the latest version of the application, and the older OS. Just a thought, as you seem to have done everything right, and the previous version worked fine on your PC.
Best of luck,
Jim K (KQ4MK)
