Using IC7300BKT with BBLogger
Unfortunately the BBLogger programmers have decided to no longer make changes to the well-known Log program, so to use IC7300BKT with BBLogger I had to come up with a small trick, that is to emulate one of the CATs already supported by BBLogger to talk to the IC 7300.
Before proceeding verify that you have installed and configured correctly IC7300BKT
Download the Bkt2Log and install it taking care to keep BBLogger closed during setup.
After the installation a configuration script is run which will ask:
  1. installation language (Italian or English)
  2. which item in the BBlogger CATs to use (CatBkt, IC706_BKT, IC7000BKT or IC7100BKT) naturally choose the one you don't use
  3. to select the BBLConfig.ini configuration file located in the folder where you installed BBLogger
Once the setup has been completed to make everything work, open BBLogger and from the Tools menu select the CAT selected in point 2.
