12-03-2016, 05:57 PM
Ciao, Mauro.
I am running 1.7.0 BktTimeSync and have started to have a problem with it (when having my computer awake from sleep).
1/27/16 22:32:49 --> Sync start P1
11/27/16 22:32:49 --> Sync NTP P1
11/27/16 22:32:49 --> 11/27/16 22:34:49Sync NTP OK, next to :
11/27/16 22:34:49 --> Sync start P1
11/27/16 22:34:49 --> Sync NTP P1
11/27/16 22:34:49 --> 11/27/16 22:36:49Sync NTP OK, next to :
11/27/16 22:36:49 --> Sync start P1
11/27/16 22:36:49 --> Sync NTP P1
11/28/16 00:23:37 --> Failed to retreive time from NTP server 132.163.4.102 on port 123, GetLastError returned 10060Sync NTP ERROR :
11/28/16 02:12:06 --> Sync start P1
11/28/16 02:12:06 --> Sync NTP P1
11/28/16 02:12:11 --> Failed to retreive time from NTP server 132.163.4.102 on port 123, GetLastError returned 10060Sync NTP ERROR :
11/28/16 04:00:47 --> Sync start P1
11/28/16 04:00:47 --> Sync NTP P1
11/28/16 04:00:48 --> 11/28/16 04:02:49Sync NTP OK, next to :
11/28/16 05:49:31 --> Sync start P1
11/28/16 05:49:31 --> Sync NTP P1
11/28/16 05:49:32 --> 11/28/16 05:51:49Sync NTP OK, next to :
11/28/16 07:38:11 --> Sync start P1
11/28/16 07:38:11 --> Sync NTP P1
I understand from <!-- m --><a class="postlink" href="http://www.maniaradio.it/forum/viewtopic.php?f=22&t=304&start=10">http://www.maniaradio.it/forum/viewtopi ... 4&start=10</a><!-- m --> that Error Code 10060 is a timeout error.
My problem is 100% repeatable, and occurs after waking my computer from sleep.
If I press the "Sync Now" button, BktTimeSync will detect and display the correct time, but if I do not, then the program will continue with the wrong time.
Strangely, if I wake the computer from sleep, and press "Sync Now" before the problem occurs, then BktTimeSync will go into the error state in a few minutes.
If I do not press "Sync Now" upon waking the computer, BktTimeSync will detect and display the correct time on the next cycle, but will go into the error state in a few minutes.
In other words, I have to wait until the error occurs to press "Sync Now".
My system is special, but it may give you some information about fixing the problem. I am running
Guest operating system - Win7/64 in emulation under Parallels Desktop 12
Host system - MacOS 10.12.1
Hardware - 2.6 GHz i7, 16 GB RAM
When I say 'sleep' above, I am referring to the MacOS (the host system) sleeping or waking. Win7/64 is open all the time.
My guess is that some memory variable is persisting in BktTimeSync, and causing the error upon reconnection. You would have far better knowledge.
I hope this helps you track down the problem in <!-- m --><a class="postlink" href="http://www.maniaradio.it/forum/viewtopic.php?f=22&t=304&start=10">http://www.maniaradio.it/forum/viewtopi ... 4&start=10</a><!-- m -->, and perhaps my problem.
73 Parker W5ADD
73 Parker W5ADD
