Full Version: Scheduled Task Missing from 1.13.1?
Maybe I messed something up, but I installed 1.13.1 and it would not auto start with Windows. I found a reference to the Scheduled Task here on the forum that launches the program (with privilege to avoid UAC) and noticed I did not have this task. I found the .xml task and imported it, but Windows indicated that it was malformed. I uninstalled everything and found my copy of 1.12.2 and it properly installed the task and worked as expected (after the 2-minute delay). I then updated to 1.13.1 and everything is working properly.
It's possible that my copy of the 1.13.1 installation file is bad, but that seems unlikely. Just thought I would mention this.
Thanks for an excellent program—I use the GPS on my main server in my home and my other machines NTP into it.
khisel Wrote:Maybe I messed something up, but I installed 1.13.1 and it would not auto start with Windows. I found a reference to the Scheduled Task here on the forum that launches the program (with privilege to avoid UAC) and noticed I did not have this task. I found the .xml task and imported it, but Windows indicated that it was malformed. I uninstalled everything and found my copy of 1.12.2 and it properly installed the task and worked as expected (after the 2-minute delay). I then updated to 1.13.1 and everything is working properly.
Thank you for sharing your experience.
I have checked, and the scheduled task in version 1.12.2 is the same as that in version 1.13.1. I have also tried installing version 1.13.1 on a new PC, and it has successfully created the scheduled task. I don't know why you encountered this issue.
