General discussion - Problems - Bugs / Generali - Problemi - Errori
Pages: 1 2
Important Threads
- Efficiente interfaccia CAT USB by I2WQ (6 Replies)
- Using IC706_BKT with JTDX, WSJT-X and MSHV (0 Replies)
- Utilizzare IC706_BKT con JTD, WSJT-X e MSHV (0 Replies)
- How to load the registration key (0 Replies)
- Come caricare la chiave di registrazione (0 Replies)
- How to localize the program (0 Replies)
- How do I change my call sign ? (1 Reply)
- Improve remote connection client/server (1 Reply)
- How to change size and appearance (1 Reply)
- Connect using VSPE Virtual Serial Ports Emulator (0 Replies)
- Hardware Limits on CI-V Command (0 Replies)
- Connection Problems (0 Replies)
Threads
- IC706_BKT configuration page, and getting started (4 Replies)
- errore BKTExtention.dll (3 Replies)
- ic-706 on/off (2 Replies)
- Icom IC 706 S-Meter SDR german/engl./ital. (1 Reply)
- Activation Code (1 Reply)
- Loading RTX memories (4 Replies)
- Easy to make CI-V cable (1 Reply)
- Memory backup - Before I buy (3 Replies)
- program startup (11 Replies)
- PTT keying (1 Reply)
- Activation code (3 Replies)
- Still waiting on key for Icom 706 mkiig (2 Replies)
- Language problem (2 Replies)
- problema porte COM (5 Replies)
- rs232 (2 Replies)
- Can not register software, CAPTCHA will not work (2 Replies)
- Error in CW & SSB Filters (7 Replies)
- info (2 Replies)
- bktkeyercw (2 Replies)
- VSEND SEL (2 Replies)
- Uso in CW con 706 mkIIg e SB2000 mk2 (1 Reply)
- BKT Server audio (1 Reply)
- Mode-A/B not working on HF (4 Replies)
- Running IC706_BKT (2 Replies)
- registration (6 Replies)
Pages: 1 2
